3PL lower link shaft leak fix John UK
Quote:
I am looking for info on removing the RHS axle trumpet to fix/tighten the lower link shaft pins.
Good day......
Safety first....
Drain oil...block tractor, Disconnect battery.....etc,
I've replaced the lower lift pins on my Ferguson TEA-20...(1974?) as well as my Ford 2-N (2017)(same procedure)
Drain all oil from Trans, Hyd, Diff. sump...
PIC's of my 2-N Ford.(never had a camera in 1974)
Remove left hand axel trumpet.....
Remove Crown diff as one unit..do not DROP DIFF assembly!
Pins are different on TEA-20's depending on S # of Tractor...
PIC with Torque values...."2-N FORD"
There are those who remove the PTO shaft.... then inset appropriate tool...then tighten inner NUT....???
Bob..Owner TEA-20 Ferguson....MF 35 X...2-N Ford...
Cheers Bob. Yep LHS NOT the RHS.
I know you can get to one of the castalled nuts thru the pto shaft. I believe it trick and tight but can you get to both nuts, from memory think you can only get to one. IF they need replacing probably best to pull the trumpet. Think that would be less frustrating.
Ignore bit about going thru PTO, just read it in the other post. Forgot that editing has been disabled...
Hello, first of all I would not even bother to try to do anything through
the PTO shaft hole........ not even a vet could do it!!!! The axle
housing will have to be removed first. If removing the left hand side
be careful as the differential may come with it. It can be left on the Rh
shaft. Check whether you have a tapered or parallel pin. If a tapered
pin ensure that the nut will tighten it. You may have to add a washer
under the nut. Check the degree of wear on the pin and in the
housing. If it is only minimal and will tighten you can use a metal
paste such as JB Weld liberally applied around the pin and casing
hole. Allow plenty of time for it to harden.
If it’s a parallel pin and too loose for JB you should be able to team or
file the hole to a larger diameter and have a slightly larger pin
machined
. If you can increase the diameter to a known size it will give the
machinist something to work to.
The JB has proved successful on a number of occasions over the
years, the last one being a FE35 about a year ago.
DavidP, South Wales
Long time since I was on here. Hi Dave S Wales.
But ..
I just did the right hand pin sucessfully through the PTO hole. I have quite small hands. I persevered and got the split pin out. Left handed is hard for me. It took a while!!
But then the nut came easy. There should be a gasket between the external metal block and the trumpet says the drawing in the manual.
Tightening it again is a slow job. Only one or two reachet clicks are possible. Make sure you know where the split pin hole is and as it comes right and tight one click at a time pop the pin through.
A deft flick with a screwdriver to spread the pin and the jobs a good'un. Not easy but it is possible. I used Blue Hylomar on the new home made thin paper gasket and got the nut tight.
The LH side looks impossible to me.
