Hi,
I own a '52 TEA 2085 12V system. I just installed a new battery and generator (both were pooched). Now when the tractor is running, the voltage at the battery climbs slowly to about 15.5V. I shut it down when it reached this voltage because I didn't know if the voltage should be that high. What should the voltage be at the battery if the generator and voltage regulator are operating correctly? What should I check first? Am I in for a new voltage regulator or can it be adjusted if 15.5 is too high? Everything else appears to run well. Thanks for any help.
Ron
Ron
