Company Logo Shop Now
Charging voltage at battery
RonON
08-02-2020 13:10:16
Hi,
I own a '52 TEA 2085 12V system. I just installed a new battery and generator (both were pooched). Now when the tractor is running, the voltage at the battery climbs slowly to about 15.5V. I shut it down when it reached this voltage because I didn't know if the voltage should be that high. What should the voltage be at the battery if the generator and voltage regulator are operating correctly? What should I check first? Am I in for a new voltage regulator or can it be adjusted if 15.5 is too high? Everything else appears to run well. Thanks for any help.
Ron
Duner Wi
08-02-2020 16:48:44
 Re: Charging voltage at battery in reply to RonON, 08-02-2020 13:10:16
This might be of help, It is not specific to your Fergie. 15.5 volts sounds too high. I would fully charge the battery first and see if it still makes 15.5 volts. If it does I think your control box needs adjusting or replacement. http://mgaguru.com/mgtech/books/pdf/Lucas_Generator_and_Control_Box_Tests.pdf
Bruce(OR)
08-02-2020 17:22:01
 Re: Charging voltage at battery in reply to Duner Wi, 08-02-2020 16:48:44
Sounds like V/R might have a bad ground. 15.5 is a touch bit high. 14.8 is at the top of the range for GM products I believe and 15.5 is topped off for Chrysler. I would have to clean and grease the V/R ground and see what you get.
RonON
08-03-2020 03:30:53
 Re: Charging voltage at battery in reply to Bruce(OR), 08-02-2020 17:22:01
Thanks, I thought that the voltage may have been a bit high. I'll go through the suggestions for adjusting the regulator and see if that fixes the problem. Duner do you own an MG? Just wondering. I do and use Barney's site all of the time. Didn't think to go there since I've converted my MG to an alternator. Thanks again.
Ron
Bruce(OR)
08-03-2020 14:01:54
 Re: Charging voltage at battery in reply to RonON, 08-03-2020 03:30:53
MG. I would have to shrink down no less than 6 inches and about 90 pounds. Even if I lost the 90, I still won't fit.
MG. Lucas electric. Beware the dark side Luke...
Duner Wi
08-03-2020 06:04:48
RonON, I never owned a MG tho I really admired MG TF and saloon cars from way back.I have owned various English cars tho. A-C, AH, Triumph.
RonON
08-03-2020 14:44:35
 Re: Charging voltage at battery in reply to Duner Wi, 08-03-2020 06:04:48
Thanks again guys. I have a '58 MGA and you're right, it is small, low to the ground and small quarters. I'm 6'1" and about 210 but have no difficulty getting in & out. Fun to drive and has nice lines. My 1st car was an MG and I've driven many British sports cars over the years. Anyway, I'm getting off topic. I am going to check out the VR tomorrow and hopefully will be able to resolve the overcharging issue. Thanks again, Ron
Copyright © 1997-2020 Yesterday's Tractor Co.
