newbie here. Don't judge. First tractor. Im unclear on the year. Where can I find this? I have a picture posted of plate on engine but no other plates available I see anywhere. Anywho. I changed the oil before. Water present. And I ran her a few mins but overheated...today heres what happened. Yes I tested low compression on two cylinders. Absolutely 0 psi. Others were solid.
I wss hoping my low compression was just a stuck valve. Popped the valve covers and it wss rusty. Cleaned what I could. Dumped atf. Drained oil several minutes later...large amount of water in oil "again" 2nd oil change since I've had it. She over heats big time. I tore it apart hoping it was thermostat. But apparently it's been removed...so I filled with water. Operated wster pump by hand. No change in flow on open end of water pump. So the impeller is probably rusted crumbs. So either wster pump failed and they ran it stupid hot to make head gasket failure. Or its just head gasket failure.
I ran 15w40 shell Rotella.
Also is the trans and hydraulic filler by the gear shifter? Or different area? I didnt look everywhere. I popped this open and bone dry. So I filled with whatever I had laying around. Just to get something inside while she shits. Im a truck driver so I'm not around much. Fyi I'm in Texas so now worried about cold weather and thick oil.
