Charlie tuna
New User
I have to-20 6v pos ground system. I just installed new voltage regulator. I checked continuity on all wiring leading to voltage regulator- no issues. I jumped "battery" terminal on voltage
regulator to "generator" terminal on voltage regulator before starting it. When I turn lights on with tractor running amp meter reads -10. When I turn lights off amp meter reads 0. It never
goes to charge side, low idle or high throttle speed. Voltage across battery terminals with tractor off is 6.2v; and it is 6.2 tractor running. I took one of the battery connectors off( the +
ground off with the tractor running at high throttle and the tractor died. Is this a conclusive test that the generator needs to be rebuilt?
