TO 35 loader help
Dwnmich
New User
My loader stopped working on my TO35. The 3 point still works fine. Thoughts on where to begin? Thanks.
Sheared the shaft to the front pump?
Broke the pump vanes?
Plugged filter?
No oil?
Send batteries for my Crystal ball and I can tell you the exact answer.
Yeah good one - my entire post didn't go through with pics. It has a diverter valve under seat that selects 3pt or loader. 3pt works fine. Loader recently quit lifting or tilting bucket.
Feeling like this diverter is the issue yet not sure if that's the place to start. Bare w me as I'm new to hydraulics.
At least you got the spelling correct. Diverter valve might be a good place to start. Does it feel the same as usual or is it suddenly easier
to turn? Internally busted? Got a volunteer to hold the open end of a hose while you check it? Actually if you have exposed hoses, they
should fluctuate with pressure. I bet they don't flex anymore. Diverter valve might be good start to open and check operation.
Hi, When the 3pt lift is at top no pressure is present to the diverter valve.
You may try to lower 3pt at mid high and retry to operate the loader.
HTH
Bart
