scoobieguy
Hello I have a 1955 TO35 with a 102A loader, and I would like to confirm the process to drain and refill the loader hydraulic fluid.
There is a plug at the bottom of the loader where it can be drained, that one is obvious. Once it is fully drained, do I start filling it from the front filter first, or from the breather at the top?
Any additional tips on cleaning the filter and tank are appreciated. Should I flush the system with kerosene?
Would there be a strainer on the large low pressure hose?
Finally on startup I just need to lift and bring down bucket several time to work out the air from system.
Thanks
Thanks
