Re: Red Rocks cable to lever kit
Kirk-NJ
05-25-2020 06:52:37
Since this is a ferguson forum I can only assume you are mounting in a TO20 or 30 since you did not say? It's possible that the redrock lever might interfere with you starter lever. There is a
reconfiguration for the top of the combo but not sure about the step up or step down which is why you don't see many in the ferguson which is why you might have the cable system. The cable are still
available at about half the cost. Before ordering a conversion handle pop you steering box up and have a look see to see if the rod is in the way I have several shermans out if you need any
measurements. The cable system isn't bad so long as you keep it lubed up.
