Company Logo Shop Now
TractorLinks.com
Ferguson I D plates on equipment
Ron Albart
03-22-2020 08:40:29
How are I D plates pins installed & removed?
Does anyone fabricate new plates?
Thanks
Kirk-NJ
03-25-2020 02:06:01
 Re: Ferguson I D plates on equipment in reply to Ron Albart, 03-22-2020 08:40:29
George has them
Charles in Aus.
03-23-2020 22:34:28
Once removed you will find a white oxidation on the rear of the plates . This is difficult to neutralise without affecting the underlying metal . A scotchbrite pad and vinegar on the rear will work if you are careful , nothing on the front or you will loose all the details . Once washed in soapy water and dried a clear coat will seal it from further deterioration .
If you want to you can accentuate the black areas with some Humbrol model paint , but it takes an age and a straight and steady hand to do this .
Charles in Aus.
03-23-2020 00:47:36
The rivets are made from the hardest toughest steel known to man ! :x Whereas the plates are the thinnest lousiest alloy ever produced . Don't even think of trying to drill them , all you will get is broken drill bits and holes in your fingers . I have sheared them off with a sharp cold chisel , ground the surface flat [ it's usually rusty underneath anyway ] and then drilled new holes .
miner09
03-22-2020 19:05:41
Iíve ordered from the UK but there available in USA. Try to find info just canít remember where. Iíve never taken those off probably have to heat to remove rivet
graham_in_NJ
03-22-2020 09:23:38
You can try here:
https://www.vintagebrassplates.co.uk/
Probably righteous $$....
Ron Albart
03-23-2020 15:35:08
 Re: Ferguson I D plates on equipment in reply to graham_in_NJ, 03-22-2020 09:23:38
Thanks for the info.
55eu for ID plate, rivets & delivery.
What product can be used to clean the I D plates?
Copyright © 1997-2020 Yesterday's Tractor Co.
