I am installing new spindle bushings on my 1950 Ferguson to20 tractor. I noticed after fitting the new bushings to the spindle and installing the spindle into the axle the thrust bearing will not recess up into the axle and would hang out about 1/4 inch. I bought The spindle repair kit from Yesterday's Tractor which came with 4 bushings, 2 thrust bearings and felt gaskets. I removed the thrust bearing off the spindle and tried just installing it in the axle to see if it would fit and it wouldn't. I have had it apart for a little while and tried to look for the old thrust bearings to check fitment, but I must have tossed in the trash. Any help with this issue that I'm having would be appreciated.
