K.Campbell
Last fall I was on my way to my woods with my TO30, when I turned onto the road out of my drive, I felt somthing " slip" and the tractors engine went down in rpms. I attempted to adjust by using the throttle but it had nothing. I ve never been able to adjust this out, I m thinking the governor has went bad. Any ideas? I ve adjusted the governor a few times and it has improved... but not like it was. When I m done mowing and push the clutch in the engine races to higher rpms, or just running down the road to the stop sign it does the same. It s not been the same ever since. I also notice that when I manually push down the governor rod ( the one closest to the engine), I don t have much movement in it at all... it goes up.. but not down. My dad has the same tractor, so I compared all with his. His rod has movement up and down... any thoughts?
