Clutch repair TO35
What's the process to remove the dual clutch finger pivot pin, keeper pin. The finger pivot pin has roll a pin keeper and is to be pushed through the pivot pin into an hole in the casting for normal operation. Don't know why the hole is necessary. However, I tapped the roll pin further into the casting hole thinking it would slide far enough for removal of the finger pivot pin. The casting hole apparently has a bottom preventing roll pin from exiting the pivot pin. Tried drilling out the roll pin, but just break drill bits. How is this pin removed?
