Standard 23C
Mr Busy
New User
I m looking for pictures of and inlet air heater assembly on a 1958 Massey 35 with Standard 23c engine. Mainly where the fuel supply is piped from. Im interested in installing one to aid cold starting. My engine starts well with the glow plugs but any additional heat would help. Thanks
There was a small tank mounted to the rear of the
fuel tank. It was filled by the fuel returning from
injectors.
Here is a picture of a to 35 I got last summer as you can see the power wire is not hooked up. You turn the manual valve on the orginal switch was replaced so I went with a push button and crank with the heat on if no start repeat after start turn off valve.
Untitled URL Link
