Once I replace the rear wheel seals. i need to refill the gear box with fluid. I noticed the fluid was milky from water in the fluid. I am not sure how to prevent that from happening again.
The tractor seems to have lost some power lifting my post hole digger out of a hole. I have had to use a jack to get it out. I am wondering if clean fluid will help had power.
How do I properly clean the gear box of the contaminated oil, what oil should I add to the gear box, and how much will I need to buy?
