Ferguson to20 carson
Okay thanks for the responses just put everything back together today fixed up generator, new wiring and new voltage regulator. My mechanic
that rebuilt my generator gave me a new voltage regulator for 70 bucks. That my seem like a god one but the new one I just bought was fried.
He said that the cheaper ones for about 35 dollars witch I had the inside of them melts when you make a jumper wire for polarizing the
voltage regulator. But, he polarized the new one for me and I already put it on. So anyways I put everything back together and installed
fired it up and checked the voltage with a multi meter on the battery set in DCV 20. And at first it measured about 6.7 to 7.1. But then
when I ran it a little longer and turned on and off the lights the voltage incready to about 9.1 with the light on. And about 8.7 or a
little higher with no lights on. So I am pretty happy with that now all I have to do it put brad new 6 volt headlights on the front. I have
just the rear work light working now, also getting new bulb and lens for the rear tail light on the other fender. Thanks again for
everyone's responses, Much is appreciated!
