Hello. Thanks for letting me join. I am new here. I have a 1953 Tea20, gasoline, made in Coventry, England. I have had more problems with it than its really worth in my opinion. I am slowly working on it to improve its running or at least decrease the down-time. I am not a mechanic. The latest issue is my carbuerator. Its a Zenith 24T-2. It continously floods. The sequence of events is such that i had it running the other day with no problems, started fine-ish and after i was done i parked it, and turned it off. I did turn off the fuel shut-off. Now when i went to start it up it wouldnt. It is cold here currently (-6C). I used the choke while trying to start it. It wouldnt turn over. Tried but very sluggish. When inspected i found the carb to be flooded. There was gas coming out of the seal between top and bottom of carb. I disconnected the air intake hose and there even fuel in that. I did some research and found that the float could be a likely culprit. I am trying to understand the system so i can trace where the problem is or if there are multiple problems to deal with.
So questions -
1. When it does run and i am done should i first turn off the fuel supply from gas tank to run it out of gas then turn it off? Or should that matter?
2. If i do the above should the motor consume all remaining gas from the point of the fuel shut-off going into the carb? This doesnt seem to do this, so would my shut-off not be working?
3. Is just a carb kit advisable? or should i also replace the float?
Help is appreciated as i am getting very frustrated.
Thanks.
So questions -
Thanks.
