Hello everyone, my TO30 has been running good, I just had used it a little last week. Today I went to use it and it started fine like always and when I went to the field with it and lowered the spring tooth it just barely goes at full throttle. Normally I can do the field at half throttle in 1st or 2nd. When I came back where I park the tractor, it doesn't really rev up in N either. But if I move the governor rod myself it revs up like it used to.
Is the governor need adjusting?
I'm going to check the fuel delivery to see if its all good.
But I'm not sure what to do to check the ignition system. I have a multimeter.
Oh and it has been coverted to 12volt, with a 12Vgenerator, 12V regulator, a 12V coil, and Battery.
