Harry Ferguson Tractors Discussion Forum |
How best to proceed
Author |
[Modern View] |
2tractors
11-29-2019 05:49:51
My brothers got a to20 and is tired of not having lift control. I have a single clutch to35 with a hole in the block. Will his motor fit my 35 bellhousing or should he go with the zang thing?
2tractors
11-30-2019 06:17:02
Re: How best to proceed in reply to 2tractors, 11-29-2019 05:49:51
I've copied the instructions and printed for him. It does look to be simple to fab. THANKS.
TR3driver
11-29-2019 13:40:19
Zang is apparently no longer making the "Zang Thang", but I recently built one myself using the instructions from
http://fergusontractors.org/nfs/wp-content/uploads/technical-articles/Position-Control-for-20-30.pdf
Much easier than doing an engine swap, IMO; only took a few hours to fabricate and install it. I don't have a lot of hours on it yet, but in initial tests with a blade and a 5' brush hog, it seems to work very well, exactly as I had hoped. Very intuitive in operation; if you want the implement higher, you just pull on the handle and let go when it gets to the height you want. To lower, push on the handle then let go. For small movements, just bump the handle.
I bought a length of 2x3 tubing on Amazon, and cut all the flat pieces out of it.
https://www.amazon.com/gp/product/B003TPFLVG/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
I had a length of 5/16" rod laying around, but it's readily available at any hardware store. Held in a vise and heated with a propane torch to make the bends.
The square holes aren't really necessary. The large one just makes it more convenient to adjust the spring tension, but you can use a hex bolt and wrench just as well. The smaller one is for a stop to save a position, but I didn't make that piece (yet).
Didn't have any suitable cork on hand, so I used some very fine (1200 grit) sandpaper instead. It may wear out quicker than cork, but seems to do fine for the moment.
Sorry, no photos yet, and I won't be back to where the tractor is until next spring.
miner09
11-29-2019 11:28:17
Look for another good 35 Deluxe and buy it. May be as cheap as fixing either of the two tractors.
pomester
11-29-2019 07:14:15
Motor will not bolt up - This was posted here recently in reply to a question about lift control - http://www.fergy.com.au/positioncontrol.htm - the US ferguson site has instructions for DIY - I've seen other posts here over the years about it, an advanced search of this site should turn up information -
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Fast Shipping! Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ] |
Home
| Forums
Copyright © 1997-2019 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
