Bolt on alternator fe35
mf35a
Is there any bolt on alternator that fit Ferguson fe35 4cyl? Agriline has a kit to convert dynamo to alternator. I know that Volkswagen passat -97 alternator fit with some modifications. I would like to have about 90ah and the agriline is about 45ah
You'll need to fab a mount to fit the alternator you want to use.
The most common alternator used is a 10SI Delco. They are cheap and plentiful, available in the "one wire" option.
This one is a smaller frame, nice when space is limited. (see link)
Just about any can be made to fit, just a matter of matching up the pulley width and making a bracket.
Curious though, why do you want such a high amp alternator? Unless you have some type high demand accessory or are running an inverter, the lower amp alternator is plenty. Alternators require horsepower to produce a charge. With a 35 HP engine, the draw can be noticeable when full engine power is needed.
Low Profile Alternator
I have a 120ah battery and worklights back and front, all in all 6 lights
(quoted from post at 21:37:29 11/21/19) You'll need to fab a mount to fit the alternator you want to use.
This is the Volkswagen Passat 80ah alternator fitted on a Ferguson TEF
