Hi
I have a 3 cylinder Perkins FE35 and I?m continually having to bleed the system.
It runs for 15 min then bleed it then runs for ten sec then bleed then run for ten sec. Then I leave it alone.
Next day it repeats.
I replaced the bowl and lift pump as the manual pump lever was broken and it looked like diesel was seeping out around the bowl.
No difference.
The bottom bleed valve of the injector pump gets a lot of air bubbles and number one cylinder injector takes a few seconds before diesel comes out.
I think the filters need changing.
Hopefully it is not the injector pump
Any ideas?
Ta
John
No difference.
Any ideas?
Ta
John
