Followup to TO 35 pressure relief valve
From previous post but did not look for old date. I have 3 TO35 hydraulic pressure relief valves. 1st is from old original pump. 2nd came on new/rebuilt pump purchased on eBay. 3rd was purchased as 2000 lb relief valve. Had all tested to avoid possible damage to tractor. 1st valve (caused rupture of external lid lines) failed to function with 8000 lb applied pressure. 2nd valve opened at 4000 lbs. 3rd opened at 3500lbs. Tractor specs call for 2000lb relief. Where do I find correct pressure relief valve?
steve, I hope that is a good source.
Someone was trying to find a 2000lb valve a while back, tried without success to find one.
I'm thinking it was the same seller, showed to have it but when ordered came back as obsolete, NLA.
Worth a try though!
Red Green, if it turns out to be good let us know, we need to bookmark it, they are getting hard to find.
