To35 gas leak at on/off valve.
Not sure if I`m missing an O-ring where you screw in the on/off valve? Part #180 097 M1. Any advice is very much appreciated!
[/img]
miner09, Thank you joining the conversation but thethresherman`s diagram I think is my Tell. Mines leaking between #42 & #44( the nut). I`m guessing that packing has disintegrated. thethresherman, is there a MF part number for the packing? Thank you both!
Thank you RM-MN, never thought to shop at the plumbing store. I went over to a buddies & he had an assortment of different size O-rings, we put 1 #43 & 44, No leaks & fuel flowing when on. Ron, good eye, but the gasket was inside the main piece. It`s a home made 1, but doesn`t leak :) . Thanks to Everyone!!
