(quoted from post at 20:48:38 08/10/19) How do I replace the Boot that goes at the bottom of the gear shift on a TO30???
Lay it out in the sun for a couple of hours, won't be so stiff, as stated already, take the know off. I think coat the gear shift with Vaseline so it slides easier.
You may have to take a pair of pliers and stretch out the bottom once you get it on. There is a groove that the bottom ring will fit in
Ask yourself how it was done in 1950 on the assembly line.
I got hot water out of the tap and let it soak for about 5 minutes inside out.
Slide it down the shaft and turn it right side out.
Done properly it should take about 4 seconds.
Better watch out, the next machine is headed down the line and the boss desire's to know why your so slow???
Turn the boot inside out...place over the gearshift lever with concave to top. Slide down to bottom, and roll the boot down as you would put a condom on.
Wayne
