Can anyone here read this serial Number on my TO-35 ?
NWBuckeye
I can not read the serial number enough to purchase a Hydraulic pump replacement. I could really use some help friends.
Thanks.
There seems to be a mix up on the page as it states a higher Ser. number than mine for that pump, yet AGCO says different?
I wonder if they just changed the Relief valve later on? Not sure but it seems that mine was used in the Industrial model too.
Either way, I will be ordering a new pump today. Thanks Guys.
(quoted from post at 15:48:48 07/16/19)
Regardless from the ACGO parts book http://www.agcopartsbooks.com/partsbooksn/Viewer/book.aspx?book=agco/693063 your tractor with serial starting with 14 would be the old style pump
They show 3 pumps for the TO35
[list:bb6e16f3f9]HYDRAULIC PUMP (USED TRACTOR SERIAL NUMBER 179304 AND UP)
Used Tractor Serial Number 168853 And Up.
Used Prior To Tractor Serial Number 168853.[/list:u:bb6e16f3f9]
There has been much dialogue on the Topic and the replacement HYD PUMP on the TO 35..
In the Massey Ferguson Archives there is a Gentleman whom has written up his step by step adventure as in a NEW HYD PUMP and installation. Here are a couple of pics of a Gentleman here on "YT" Tractor who did not have or follow the installation or start up of a tractor that had not been ran for some time,and or assembled incorrectly..
You may be aware of the below pics.....
Good luck..
Bob...Owner MF FE 35 X
(A) Valve Assembly, Safety (3000 P.S.I.)
180962M91
(B) Valve Assembly, Pump Safety (2000 P.S.I.) (Order 891844M91)
(A) - Used Tractor Serial Number 168853 And Up.
(B) - Used Prior To Tractor Serial Number 168853.
