Company Logo Shop Now
TractorLinks.com
Delco Distributor question - TO-35
livetooextreme
07-11-2019 15:40:49
I'm trying to rebuild the distributor on my TO35. However, I can't get a wrench on the nut that holds the points and and condensor wire in the pics below. The points are in the way. Do I need to remove the black block that the wire from the coil hooks to on the outside of the distributor? Any ideas how to get that stuff apart?
Thanks!
livetooextreme
07-12-2019 14:44:54
 Re: Delco Distributor question - TO-35 in reply to livetooextreme, 07-11-2019 15:40:49
Thanks! A standard open end wrench doesn't fit because of the position of the nut, the plate below, etc. Kind of hard to explain but I can't get a open-end on it.
I'll give some of the suggestions a try.
John Deere D
07-11-2019 23:01:40
I've had the best results with my Ignition open ends:
Bob..Pics off Internet...
miner09
07-11-2019 18:09:01
Use a wrench 5/32 I think-have to look.I have a wrench that is just for this. Pliers will round shoulders.Loosen it and it will slide back but be sure insulator in notch in housing when replacing.I think when you loosen nut you can slide bolt out and tighten nut on outside to keep this from happening next time.
thethresherman
07-11-2019 18:04:31
5/16 open end wrench works great.
Tom h.
07-11-2019 16:04:46
Yes you do need to loosen the nut to remove the point. Iíve had good luck using needle nose pliers. A small wrench would of course do better. Put a drop of oil on the threads to help.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
