Company Logo Shop Now
TractorLinks.com
Sudden lift loss
Grabatire
07-08-2019 10:25:07
While a friend was using his Fergy the Three Point Lift suddenly lost lift. The key word here is 'suddenly'. It tries but no go.
The pump has recently been overhauled, including a new safety valve and control valve and the lift cylinder got a new piston with the O-ring.
What would be the likely cause?
Grabatire
07-10-2019 20:19:43
 Re: Sudden lift loss in reply to Grabatire, 07-08-2019 10:25:07
Dan S. You may have hit the nail on the head. When the pump was being installed the gasket took a bit of a beating. If the part of the gasket that serves to seal the stand pipe suffered it may have only held for a while then blew out entirely.
John Deere D, thanks a lot for the pictures.
marloweg
07-08-2019 19:07:31
just had one blow the gasket on the lift piston the one between the cover and cylinder
Grabatire
07-08-2019 17:24:17
Dan S.It is either a TO20 or TO30. I'm wondering if the control linkage has slipped out of adjustment. He says it tries to come up but that's all.
Dan S (NY)
07-09-2019 09:35:54
 Re: Sudden lift loss in reply to Grabatire, 07-08-2019 17:24:17
The pump gasket that seals the stand pipe could have failed. Also make sure the control arms haven't come off the valve in the pump.
I would take off the right side cover and use a light to look for any leaks. Don't reach inside with your hands with the tractor running! You can also try using a dowel or long screwdriver through the side cover to move the control arms and see if that will raise the lift.
Dan
Charles in Aus.
07-08-2019 14:36:16
Try lifting the arms by hand a few times pushing them down hard after each lift. Chances are a stray bit of grit has jammed the valve or is stopping it from seating . The rush of oil can dislodge the trouble. Worked for me on my FE35.
John Deere D
07-08-2019 23:47:26
 Re: Sudden lift loss in reply to Charles in Aus., 07-08-2019 14:36:16
Possible area of foreign material located...?
Bob...Owner Operator TEA-20...MF FE 35 X...Ford 2-N
Dan S (NY)
07-08-2019 14:02:56
What model Ferguson does he have? TO20/TO30 or TO35/F40?
Dan
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
