Company Logo Shop Now
TractorLinks.com
TO35 Fueling Issue Help Please
06motorradman
07-06-2019 20:19:51
I am helping a friend get her TO35 running properly. It has the continental gasoline engine, and it appears to have a TSX carburetor. It starts when choke is pulled, but will only run when choke is held on, even when warmed up. It sat over the winter and the fuel sediment bowl had a lot of junk in it, and the air filter was filthy and full of sludge. Sea Foam did nothing. I cleaned the air filter, sediment bowl, and drained the carb bowl. It ran fine when I mowed with it over a year ago. A couple of other people have mowed with it since then but they didn't do any maintenance.
Does it sound like I need to remove and clean the carburetor completely?
Do you disconnect/reconnect the linkages with the carburetor unbolted? Access is limited.
How do you adjust the idle wingnut that is behind the carburetor? It it's cramped in there between the manifold, with the fuel line, air hose, plus the heat from the exhaust manifold.
06motorradman
07-08-2019 18:16:52
 Re: TO35 Fueling Issue Help Please in reply to 06motorradman, 07-06-2019 20:19:51
When I drained the carb bowl, the fuel looked ok. I think I'm going to remove the carb and clean it.
Do the bolts typically get frozen? Should I use penetrating oil on them before I try to loosen them?
Does the power valve screw get richer when you turn out CCW, or in CW?
Steve@Advance
07-08-2019 04:41:09
Pull the drain plug on the bottom of the carb, catch what comes out.
If nasty, the tank will need to come off and be rinsed out with E85.
Check the flow, should have a healthy stream, not a drip or stop completely. If not a good flow, check for restrictions back to the tank. There should also be a screen in the carb inlet elbow. If there is an inline filter, that can be the problem. They don't do well with gravity flow systems.
The carb may also be contaminated inside. Usually it can be removed, eased apart and cleaned without a kit, just be careful with the gasket. It is easier to disconnect the link from the governor arm than trying to work behind the carb.
06motorradman
07-07-2019 19:39:36
Where is the breather on a TSX carb?
steve19438
07-07-2019 08:44:03
might not be a bad idea to check the air cleaner for blockage. especially the cup at the bottom.
2tractors
07-07-2019 05:47:28
Make sure the breather is clear before adjusting then try turning the main jet out so choking is unnecessary and yes the connections are made with the carb hanging loose.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
