Ferguson 35 Power
Diesel?
Gas?
Depends on your desired foreword speed...IE .... 4.5 MPH?
Depends on what you are cutting?
Depends on your height of material you are cutting...
Bob. Owner operator MF FE 35 X..3 cylinder diesel...44 HP...I cut with a 48 "....1st gear High Range...Engine RPM 1700....
Grass....24" tall
Tractor handles it easily..
I have 1 I use occasionally but it is actually too big ,a 5 footer would be better for this tractor especially on hilly ground
I've used both 5' and 6' mowers on my 35.
IMHO the 6' mowers are a bit much. You can get by with them on level ground if you don't push too hard. But a 5' mower is more suited to the tractor.
