K.Campbell
Well my ferguson is running nearly perfect, I now need to turn my attention on the braking system. I have one side that works and have little play on my brake peddle to engage it. The side that works also has a weird noise just before it stops... I m sure that most here have experienced that noise... what is it? Just before it stops it makes a sqealing noise.. but when applied at high speeds no noise. The other side doesn t work. I m going to try and adjust them tomorrow. However if I need replace the shoes is that a big job? Tractor has sat inside it s entire life.. no rust anywhere to be seen..I don t have an IT manual.. thanks..
