Company Logo Shop Now
TractorLinks.com
Remove Rotor on distributor TO35
livetooextreme
06-08-2019 16:40:36
I'm working on my first distributor. It's on a TO35. I'm not getting spark, but I have power to the distributor from the coil. I removed to distributor cap, but now I can't get the rotor off to remove the dust cover/cap to get at the points and condensor. Is there some sort of trick or way I need rotate the rotor?
As a side question, what should the coil ohm at? I'm getting 3.7 primary and 8.5k-ish secondary.
Thanks in advance.
Ed H.-OH
06-10-2019 14:11:46
 Re: Remove Rotor on distributor TO35 in reply to livetooextreme, 06-08-2019 16:40:36
Hello, A lot of old timers glued them on , on the mag on my Wisconsin i always glue it or it will start working and break. Heat it and melt the glue- I just break them off----Ed
livetooextreme
06-09-2019 16:10:07
Man, it just won't come off. I'm chipping chunks off the rotor trying to pull it off with the pliers but it won't budge. Any thoughts? I just don't want to damage the shaft or anything I shouldn't.
livetooextreme
06-09-2019 16:00:31
Thanks. That's what I thought. It must be rusted on or something because I pulled on it fairly good with a pair of pliers and it didn't budge. Maybe I just need to give it some more muscle. I just didn't want to damage anything. I'm buying a rebuild kit for it and replacing the rotor anyhow.
Tom h.
06-10-2019 05:45:46
 Re: Remove Rotor on distributor TO35 in reply to livetooextreme, 06-09-2019 16:00:31
You should be able to tap it off with a screwdriver and hammer, break if needed you are replacing it anyway. While it is off add some oil in the space under the rotor, that lubes the shaft for spark advance. There should be a small felt disc in there.
thethresherman
06-08-2019 19:33:09
The rotor should just pull off. There is a spring clip inside the rotor that helps wedge it onto the distributor shaft. Coil readings are good. Primary when new about 3.2 ohm. Secondary varies but you are in the ballpark.
phil(va)
06-09-2019 14:55:58
 Re: Remove Rotor on distributor TO35 in reply to thethresherman, 06-08-2019 19:33:09
Some of the Fords have the clip inside, but my Fergies don't.
miner09
06-09-2019 13:58:21
There is no spring on the rotor. Just pull up. It's just stuck.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
