I bought it knowing 3ph would not lift implement.take off implement and arms would
raise.I pulled side covers and saw no telltale signs of a leak.I bit the bullet and
bought new chambers,complete rebuild kit,relief valve,control valve,lift cylinder and
piston. So now lower arms raise my 300 lbs on drawer but if I put any implement on
lower arms come up until weight gets on toplink.Then it stops! I can help it raise by
lifting the implement manualy..kinda taking some of the weight off the tractor.Any
ideas??? Draft spring is free and set right according to manual.And I am running 90wt.
N-series fluid from TSC.
