All,
I have a fergy to-35 that I cannot seem to cure. The tractor starts right up and runs fine but surges. Low rpm, high rpm, idle, it always surges.
I have removed the marvel-schebler carb and cleaned it multiple times. Replaced fuel strainer at 90 degree in carb and cleaned sediment bowl.
I am leaning towards a governor issue.
Can anyone give some direction before tearing into the timing cover?
Could I have a vacuum leak? If so how do I test for one?
Thank you all very much!
