Company Logo Shop Now
TractorLinks.com
regulator
andrew davis
05-11-2019 14:32:32
So I notice my TEA 20 is not charging. I removed battery to charge and saw that the unit under the battery (regulator?) had 4 wires coming out and one (second from the right/yellow) was not in the back of the unit. not sure how it connects in the unit are if that is the problem. This yellow wire goes to the dashboard amperes device. all suggestions welcome
John Deere D
05-11-2019 23:18:16
 Re: regulator in reply to andrew davis, 05-11-2019 14:32:32
TEA-20........6 VOLT..POSITIVE EARTH
Bob...Owner TEA-20 6 Volts LUCAS Generator / Electrical system:
Andrew Davis
05-12-2019 04:51:57
 Re: regulator in reply to John Deere D, 05-11-2019 23:18:16
Thanks for the info. I have a 12 volt system though. Just want to know how to take apart the regulator. Do not want to do any unnecessary tinkering.
John Deere D
05-12-2019 07:40:52
 Re: regulator in reply to Andrew Davis, 05-12-2019 04:51:57
See Info from Manual as per pictures:
Bob...
Steve@Advance
05-11-2019 15:09:47
Yes, that wire needs to be connected to the regulator.
Depending on how it's labeled, it will go to the "A" or "BAT" terminal.
Be careful not to let the wire touch ground, it is hot from the battery.
Andrew Davis
05-11-2019 17:29:04
 Re: regulator in reply to Steve@Advance, 05-11-2019 15:09:47
The battery is disconnected. How do I reattach? It appears that the other wires going to the regulator are short and will not let me pull the unit all the way out. I guess I would need to disconnect them from where ever they go to to pull unit out. I do not want to do unnecessary stuff if I do not need to.
miner09
05-11-2019 17:24:44
Take battery cable off when reconnecting wire. Then your safe.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
