I was running a plow through the garden late yesterday with my 1951 TO20 when the steering suddenly became very tight. It's not completely frozen in place, as I can still get it to move just a little but it's so tight that I'm sure forcing it will break something. I stopped trying when I heard a faint crunching sound coming from the upper area of the steering housing.
My plan is to lift the front tires off the ground this afternoon and see how that affects things. If that helps, wouldn't that indicate a problem with the spindles? If the problem is in the steering housing, say a failed bearing or some such, it seems taking weight off the front wheels wouldn't really help matters. There doesn't seem to be much inside the steering housing that could bind things up, unless one of the #6 bearings shown below has seized up.
Any thoughts on this before the wrenching sets in?
