Mblaxland33
Hey all,
I recently bought a TO35. It?s my first tractor and I?ve been
disassembling it, cleaning, and painting it. As I?ve come to the
back of the tractor I?ve gotten to the hydraulic system and 3pt
hitch. In another thread I questioned the 3pt hitch dropping
rapidly (in less than 10 seconds with no load). As the hitch still
works currently I think I may leave well enough alone for the
time being however I have the following question:
I opened the inspection cover and the oil was slightly
overfilled, and it was a caramel-brown color. I also removed
the drain bolt and got about a tablespoon of slightly lighter
Carmel colored oil and then a steady stream of the caramel
brown oil. Based on what I?ve read here, this is a good color
for the oil? Is there a need for me to change it?
Additionally I noticed that there was some ?crud? on some of
the surfaces inside the inspection port. Almost like some oily
dirt? It seems to have caught in some of the corners of the
parts visible through the inspection port. Is this ok/normal? Is
there a need to clean this all out or is it better left in-disturbed.
Considering the lift already falls quickly (possibly worn pump
rings?) is it necessary to do anything in the meantime to
prevent more wear or damage? Or should I leave well
enough alone and address the issue when the lift gets worse?
