Mblaxland33
Hey guys,
Right now I?m in the process of dis-assembling a TO35 that I bought. When I removed the crank case breather tube I noticed that it has some greasy sludge in the end. So, even though I wasn?t necessarily planning on dis-assembling the motor, I removed the rocker arm cover. When I did I found the whole compartment to be coated in this greasy sludge. Is this typical? Or have I just opened a can of worms for myself? The tractor ran well before I started disassembling, with the exception of a hesitation I associated with a governor or carb problem. Thoughts?
