I'm back to working on a TO35 (my unending nightmare tractor). I am having trouble with the clutch. In the first stage it shifts in and out of gear smoothly however when I push the pedal all the way down to engage the PTO I can't get the PTO to engage. It acts as though the main clutch is not completely disengaging and letting the pump shaft stop. I have inspected and adjusted the secondary clutch plate through the inspection hole and the problem still persists. I have also adjusted the clutch free play back into spec. I am sure at this point that splitting the tractor is probably the next move, but does this sound like an issue with the main clutch? possibly clutch fingers out of adjustment? I do know that to reset the clutch fingers I have to put a new disk in it. Is there anything else I need to look at? anything I'm missing?
