I'm gradually working through the electrical system on my recently-acquired TO20 and still trying to pin down exactly what I've got here. The battery was stolen from the tractor sometime during the past two years, so that's of no use in identifying what's going on. The widow I bought it from proudly pointed out the tractor still had its original 6v electrical system and I can see where she got that, with the coil being clearly marked as such:
In comparing my wiring to the 6v diagram, I see no reference whatsoever to there being a resistor used in this system. Look inside the red circle at the top right of this photo. Hmmm:
Just a few minutes ago, I was reading through some technical articles over at fergusontractors.org and ran across the following details:
[i:6c0d65e996]CONVERTING A 6 VOLT FERGUSON TRACTOR TO 12 VOLT (using a 12 Volt Generator)
1. Secure a 12V generator (Delco models 1100359, 1100362, 1100434, 1100435, 1100529, or 1100998 will fit and you can use the same mounting bracket). [color=blue:6c0d65e996](My ID tag has thus far proven illegible, so I don't know what I've got)[/color:6c0d65e996]
2. It is best to replace the 6V coil with a 12V unit with a built-in resistor. [b:6c0d65e996]An alternative is to continue to use the 6v coil and add a ballast resistor in the line from the ignition switch to the coil.[/b:6c0d65e996]
3. You will need a 12V battery. Ground it negatively.
4. Reverse the wires on the terminals of the ammeter.
5. It is not necessary to replace the starter with a 12V unit. Just don’t crank the starter for long periods of time as it will heat up a bit sooner than a 12V unit will because of the extra voltage.
6. If you have lights you will need to change the lamps in the headlights and work light and the bulb in the taillight to 12V. [color=blue:6c0d65e996](My lights are all disconnected!)[/color:6c0d65e996]
7. You should polarize the generator, particularly if it has been unused for a long period.[/i:6c0d65e996]
I'm thinking the questions to ask at this point would be:
a. Is there any reason a resistor would've been added to a 6v system aside from the explanation above?
b. Is there a way to test or otherwise identify a static generator to determine if it's 6v or 12v?
c. Is there something simple or painfully obvious you more experienced fellows see in the photo that suggests what voltage I'm working with here?
Thanks in advance for any help. John
