transmission leak and fix.
Well I have a leak out of my weephole in the transmission. It's the hole that has the cotter pin, in front of the oil pan. So anyhow, I am going to order a transmission input shaft seal....is that all I need? I've consulted the manual, but can't tell. I figured I'd ask the experts.
I know I need to split the tractor, no biggie there..I know I need to remove the clutch assembly...not a problem. Is there any other gaskets though that I will need to purchase to finish the job?
That leak could be either the transmission input shaft seal or the rear main seal on the engine
hi guys, it's definitely the transmission leaking. I have mineral oil in the transmission and regular motor oil for the engine. It's leaking the mineral oil. There is one seal shown on here for sale, the input shaft seal. Is that indeed the correct seal I will need?
the only part number I see that is the transmission input shaft seal for a ferguson TO30 is this part number ...8N7052A. All my the part numbers I see are in the description of the part, below the picture of the part...possibly I have a different version of the parts catalog, I’m using my iPhone, sometimes that makes a difference.
