55TO35Deluxe
New User
Hello folks!
Brief intro:
Ive had a couple of old Ferguson tractors, and I'm currently working on a 1955 (HF stamped castings) TO-35 with dual stage clutch. Serial number plate was missing when I got it, and I had to make some adjustments to find out I had the dual stage clutch... but it does work. The guy I bought it from had completely rebuilt the Z134 gas engine (manifolds and all) and ordered a new hood and gas tank. I rebuilt the carb and added electronic ignition and replaced the starter, water pump, and alternator... runs great
Anyway, the lift works but has leaked down rather fast when turned off since I got it. I was digging some azalea roots up with my box blade hooks for my wife's flower garden spot and the hooks hot hung up. I backed up and tried again to go forward , and that's when the position control lever went 'limp' and stopped working. It now just slides up and down with no tension on it and I have to use the draft control to raise and lower the lift.
My question is this: Since I already know the pump leaked down a little, I want to go ahead and replace the pump. The problem is that all of the hydraulic pumps I see here and elsewhere are advertised for[b:2d551390d8] "TO35 serial number 179304 and up"[/b:2d551390d8] . I know the 1955s were serial numbers 140xxx-160ish. So where can I get a replacement pump for a 1955 serial #143xxx tractor??
Thanks in advance, and happy Veterans Day to my fellow vets!
Brief intro:
