Gentlemen,
I have run into an issue and I am trying to trouble shoot.
I have a 1952 TO-20 Fergie which was converted to 12V by the previous owner. The previous owner also added an ignition button.
When I bought the tractor it ran just fine but the starter sounded like there was something loose inside. I replaced it with a rebuilt 12V starter bought from this website.
The tractor ran fine again for a while. I decided to clean the carb and change out the points/condenser. At this point I cannot get the tractor started. I suspect it was my changing of the points...
At this point the tractor will attempt to turn over approximately 2 times, and then I get nothing. No movement on the starter, no more attempts to start. The battery is good.
Any suggestions on where to go from here?
Thanks in advance!
Thanks in advance!
