To35 clutch
Update on my clutch problem. It appears that the pin that holds the clutch leaver slipped out. This allowed the leaver to fly up and catch the housing. The leaver broke in half. Any idea where I can but only the leaver without having to buy the entire pressure plate? It is the dual clutch and the best I can tell the pressure plate is a 182463M93 part number. I can not find a part number for the leaver.
The lever is #1 753 750 M1, pin# is 181 119 M1 and spring # 181 125 M1. There are some changes at different tractor serial #s so I would really need to know tractor serial to make sure my #s are right.
Dave, parts and reference#s
Dave, the changes were after #177395 so my numbers should be right. If you can't find the parts, we have an older MF dealer I could check with and if he has them he might ship. My 35 is # 145609 so not much older than yours. Jim
Dave
Clutch finger should be available at your local Massey dealer. Spring and pin are no longer available, but I may be able to find them if you need? E-mail is open.
Wayne
