When installing the aluminum oil pan on a TEA 20, do you use a gasket adhesive, gasket sealant or RTV gasket maker etc. when using the heavy paper gasket? If you do, what make & type do you use. Do you apply it to the pan and put on the gasket, then apply to the gasket and install pan on block. How do you ensure that none gets into the interior of the engine? Some recommend applying grease (some specify bearing grease) to both sides of the gasket and then install pan with gasket to block. Do you do the same for the oval access plate for the oil strainer? Any tips, advice etc. appreciated. Thanks, Ron
