Company Logo Shop Now
TractorLinks.com
John UK
RonON
10-10-2018 06:00:37
A few years back I was in contact with a John UK by email. He used to post on the ferguson forum here. I have tried to contact him recently but have not received a reply. Does anyone have a contact email for John UK or some other way of contacting him. Thanks. Ron
Toora Stephen
12-10-2018 16:20:46
 Re: John UK in reply to RonON, 10-10-2018 06:00:37
I was in contact with John a few years back. He was very helpful. Even back then he was on and off the forum with bad health. I don't think he'll be back.
- TS
Charles in Aus.
10-15-2018 22:06:31
Wherever John is and however he is travelling I wish him the best . He has helped so many countless enthusiasts , selflessly and with such expertise .
Thank you John .
fusion
10-15-2018 08:27:46
I have (2) E mails for John
fergusontractors@hotmail.com
fergusontractors@tiscali.co.uk
The last I heard John he had health problems.
steve19438
10-10-2018 17:00:17
J-UK helped me in 2014 with TO-35 hyd. problems. that's the last I've heard from him.
Bruce(OR)
10-10-2018 06:31:49
He was old a few years ago. Then he got ill and the postings came to an end. Just curious, what are you trying to do? Year, make, model and problem??
RonON
10-10-2018 08:13:30
 Re: John UK in reply to Bruce(OR), 10-10-2018 06:31:49
third party image
Hey Bruce, I have a 1952 Ferguson 20-85. I am trying to replace the rear crankshaft seal. I had instruction from John UK which I followed except I did not empty the oil from the engine which after rereading was suggested) and remove the oil pan (which he didn't have in the instructions, he just had removing the small oval port in the side but I don't know why). So I have the tractor split and sitting on blocks/jacks and cannot figure how to get the old seal removed and the new one installed. I have posted questions here and replied to replies this morning. The one reply was good except it dealt with replacing the seal during a motor rebuild so the oil pan was off, engine upside down etc. I would like to figure out if I need to remove the oil & pan to get at the crank block to replace the seal. If you wouldn't mind looking at my earlier posts/pictures and make any suggestions I would appreciate it. I also have a question about the front gearbox seal. I looked at it and it doesn't seem to be leaking (see picture). I know that the seal is cheap but I generally don't replace it if it isn't broken. What do you suggest. Also what is the easiest way to replace the thrust bearing and pilot bearing? Thanks for any help that you can provide. Ron
Bruce(OR)
10-11-2018 09:32:47
 Re: John UK in reply to RonON, 10-10-2018 08:13:30
It would appear the oil pan needs removed and clear access to all the fasteners will become evident. As for the thrust bearing, a pic of that might be in need. Sometimes, thrust bearings are pushed unto a sleeve that becomes part of the assembly. The easiest way to do this might be a usage of a steel punch for removal and perhaps a brass drift for installation.
Bruce(OR)
10-11-2018 07:56:54
Pilot bearing can be 'hydraulic-ed' out. Find a dowel the same diamter as the pilot bearing. 1/2 inch extension? Fill the hole in the back of the crank with grease. Drive the dowel into the hole. The grease will force the bearing out.
John Deere D
10-10-2018 22:52:49
third party image
When the day arrives, I have to change out the throw out bearing for the clutch.....
I shall Fabricate something similar to this tool......
Tool picture, taken from TEA-20 SERVICE MANUAL...
Bob...
John Deere D
10-10-2018 10:03:37
Ron......
Please explain as to the Thrust Bearing location?
Engine?....Transmission?
Bob..
RonON
10-10-2018 14:19:10
 Re: John UK in reply to John Deere D, 10-10-2018 10:03:37
Sorry Bob. It is the throw out bearing for the clutch. Ron
