if it is run off the front pulley, you *might* have a -- of a time locating a front loader drive pulley for a TO-20.
They are still available for the Fords of that era as well as the TO-30, I believe.
The TO-30 is a larger diameter and I seem to remember it will not fit.
Last time I chased this worm has been several years so the parts availability might be different now.
If it plumbs into the rear hydraulics, then it is a straight across trip.
If it is run off a remote front pump, then you can fab the mounting bracket for your Fergy.
After you get it installed you might find the steering is a bit difficult. That can be overcome either with a Jackson power steering unit,
bring some money, or by lengthening the top of the spindle arms on top of the steering knuckles. Lengthening those arms will increase the
turning radius of the tractor, but that is overcome with the usage of your steering brakes.
That is why.
So are you going to get the loader or not? I have two or three out here in my yard. Five including the two that I use. . . .
