1952 Fergy TO-30, 6V positive ground.
I had some trouble with it last year not starting, turned out to be a bad starter, so I replaced that. This time I go out there, it started right up without choke, but yknow how if you engage the PTO and let go of the clutch it will stall out sometimes? Well, it did that, when I went to start it- nothing. The battery was at 90% charged up to 100% in 5 min. I took a cable from the neg/batt post to the starter nothing- not even sparks. All wires are tight. Tried touching both posts on the mech switch with screwdriver, nothing- not even sparks. What could be the issue? Thanx in advance for your help.
