Tea20 oil leak from front of sump cover.
kaesark
I have an oil leak from the front left hand side of my sump cover. It appears to be running from the left front left hand sump bolt. Is this possible, I did not use any casket cement on the sump gasket but was meticulous in cleaning the surfaces. I am 100% sure it is not from the timing cover.
I guess it a case of dropping the sump and applying casket cement then.
