TO20 Clutch replacement Long vs. Rockford
dmkone
New User
Ordered a replacement clutch for my TO20 from Yesterday's Tractor. Received a Rockford clutch, disc, and bearings. Upon splitting my tractor I discovered I have a Long clutch. Are the two interchangeable? Any adjustments required to the throwout bearing linkage or the Rockford clutch. Design appears to be same concept but Clutch pressure plate packaging seems larger on the Rockford. Don't want to put it together only to have to tear down again. Any advice is appreciated.
Thanks!!!!!
Dennis
Where did you get your kit from?Yours should be a 9 inch kit.Brand should not matter as long as the size and splines are the same.Scott
