Used a sure seal to stop a leaking seal on my 1948 TE 20. Axle was difficult to get out of the axle housing. Next time will make up some type of slide hammer to remove the axle. Wanted to know how others on the forum have removed the axles on their TE 20"s. Some good you tube videos by " Bundy Bear " but unable to fine a you tube video on removing the axle from the axle housing.
Used a piece of 3 inch heavy PVC over top of the axle to install the seal. Someone on the forum gave me the idea of using a piece of pvc. Cut a piece of 3 inch pvc to extend over top of the axle.Put a piece of wood on top of the pve and tapped the sure seal into the housing.Went in perfectly Packed recess in front of the bearing with axle grease
