Re: TO30 pto shaft won’t pull out and intro
miner09
09-13-2018 19:47:17
If you got bolts-- retainer ring off then take large channel locks and turn housing and pull out. It has two places on retainer where ring fits is where I clamp. It has a O ring around housing (inside)that sticks and when you turn it comes loose.Keep turning and pull at same time. Drain oil since it has water in it.You need a seal to stop leak.
Pigeye
09-14-2018 04:14:00
 Re: TO30 pto shaft won’t pull out and intro in reply to miner09, 09-13-2018 19:47:17
For clarity; when you say housing you mean the bearing housing?. And you think that the o-ring is what’s catching? I ‘ll run with that. I don’t think the shaft is bent, everything works great otherwise. Just preventative maintenance( breaking what was fixed).
miner09
09-14-2018 07:03:32
 Re: TO30 pto shaft won’t pull out and intro in reply to Pigeye, 09-14-2018 04:14:00
Housing that the pto shaft come through . Part that you will pull-turn.
